Poor-sche Lover's Avatar
Just How Expensive Will This Be?
My winter projects have begun, and first on the list is fixing my door. As you can see from the pictures, the plastic pieces are cracked/broken. As a result, my window does not seat correctly into the weatherstripping when I close the door. Before I start tearing things up, I'd like to know what to expect. Is this going to be bad enough to require a new door, or can I buy pieces to fix it? Thanks in advance.
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 11-13-2008, 02:47 PM
dealer items and cheap
and not likely the cause of your door not closing properly- more like a symptom
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-13-2008, 02:54 PM
kilodawg's Avatar
I'm a little confused (not unusual) but the only thing you are showing that is wrong is the crack in the end cover plate. This seems to occur frequently when the attaching screw is over tightened. In black these are cheap to replace.
I had a cracked one on my '88 slant but it was mahogany in color so hard to source a replacement. In that case I removed it an super glued it very carefully from behind. The repair was perfect and you can't even see the original crack from up real close.
As to your ultimate "problem" I think you need to dig a little deeper....
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 11-13-2008, 02:58 PM
I wasn't so concerned about the little cover plate as the crack in the window frame. It's hard for me to tell if it's just the little rubber piece that's broken, or if it's the whole frame. What would one call these two pieces?
Alan
Old 11-13-2008, 03:03 PM
I think you are about to acquire a new rewarding but time consuming hobby, cabriolet window adjustment.
Rick
88 Cab
Old 11-13-2008, 04:06 PM
Sports Purpose 911 Driver
mjshira's Avatar
LOL! I can agree with that!
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 11-13-2008, 04:12 PM
As they say, "well, there's yer problem!" The bracket that holds the bottom of the window frame is busted. I guess it's time to start a search for "window frame bracket thingy" Somebody has clearly already been in here.
Alan
Old 11-14-2008, 05:12 PM
Monza_dh's Avatar
try dcauto
$35 and a six pack to my name.....
'88 Diamond Blue Carrera CE 3.4-SOLD
Old 11-14-2008, 05:16 PM
find the other half of the bracket and weld it back on. as for the window frame crack, that's just a plastic cover piece.
206 637 4071
Old 11-14-2008, 07:26 PM
