Forever a Newby
maybe368's Avatar
Send a message via MSN to maybe368
66 912 No bright Headlights
I have spent the better part of 2 days trying to figure out why I have no brights. I can apply 12 vdc to #57 on the headlight switch, the grey and green wire that activates the bright relay and, voila, I have brights. My question is Where does #57 on the headlight switch get its power? Is it from the switch internally? I have to defer to Sterling that these curcuits are far from simple. The dims work fine and I have removed and cleaned the multiswitch. That is another complicated issue. Any help would be appreciated....Mar
I can pretend with the best of them, I just cannot pretend that I am not pretending
Old 01-11-2009, 08:48 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
ook at my thread on sporto cosmetic restore and see if the last few post helps.
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 01-11-2009, 09:22 PM
Forever a Newby
maybe368's Avatar
The link does not work...can you try again....thanks Mark
Old 01-12-2009, 05:05 AM
UNDER CONSTRUCTION!
try this
1975 911S sporto cosmetic restore
Old 01-14-2009, 06:20 PM
