wannabee wannabee
WIL84911's Avatar
heater blower stopped working on 3.2
checked the engine compartment fuses and they appear to be fine. did not find haynes manual to be helpful. can i assume blower motor is shot? this is the motor directly following the heat duct from exchanger in the engine compartment correct? help please... thanks!
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 11-09-2008, 07:59 AM
wannabee wannabee
WIL84911's Avatar
forgot to mention I was referring to the blower controlled by the switch above the heater levers. thanks in advance....
Old 11-09-2008, 08:09 AM
Recreational User
porschenut's Avatar
Don't assume it's a malfunctioning blower motor, as it could also be the heater relay which sits just above the 3 fuses in the engine compartment.
Check for voltage at the blower motor connector with the heat switch on and the engine running. If no voltage, suspect the heater relay ($210 or thereabouts).
And by all means, buy the Bentley manual which is much better than Haynes and includes heater troubleshooting procedures.
Old 11-09-2008, 08:25 AM
Recreational User
porschenut's Avatar
And take a look through this page, which contains a wealth of information on the heater system:
http://members.rennlist.com/imcarthur/911autoheat.htm
Old 11-09-2008, 08:27 AM
wannabee wannabee
WIL84911's Avatar
thanks very much porschenut... will definitely look into your suggestions.
Old 11-09-2008, 08:33 AM
gjs
glennspiegler's Avatar
This just happened to me. Turned out to be the little air intake motor behind the dash. The fan was turning and not bringing cabin air past a sensor (round hole), due to dust. Blew it out and its worked fine since. This unit appears to control power to the system and can give your symptoms.
Old 11-09-2008, 01:54 PM
wannabee wannabee
WIL84911's Avatar
thanks glenn... will check that as well. was surprised when it ran once more a few minutes ago (took my kids to the park) then stopped again.
Old 11-09-2008, 02:32 PM
blower motor
I have had intermitant blower motor operation on my 74 911 in the past and recently it has stopped. About 15 years ago, I took the blower motor apart and installed new brushes. I took some generic brushes and filed them down to fit in my motor. The soft iron brushes are very easy to shape with a file. This will probably be my next project to do again.
Old 11-15-2008, 06:39 PM
