-   -   Need help with front targa seal replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/441458-need-help-front-targa-seal-replacement.html)
Paul K 11-15-2008 01:51 PM
All:
Just got my new targa seal from Dan Petchel. I went to remove the old one, and it turns out there are two separate rubber pieces along the top of the windshield- the thick seal part (like I just got from Dan) and this thinner strip which runs along the leading edge, as shown below;
http://forums.pelicanparts.com/uploa...1226785705.jpg
Do I just install the piece Dan sent me (as seen laying on the windshield) or should I try to replace the thinner strip also?
Thanks in advance,
Paul.
gsmith660 11-15-2008 02:20 PM
That is a fix to eliminate wind noise
http://forums.pelicanparts.com/uploa...1226787586.jpg
HarryD 11-15-2008 02:25 PM
I would e-mail Dan and ask but it looks like the seal in the lower part of the page gsmith posted.
gsmith660 11-15-2008 02:26 PM
Thats what it is.
Paul K 11-15-2008 02:39 PM
Thanks guys. I now know the extra trim piece was added by the factory. I just talked with Dan Petchel- it sounds as though there may be a trim part missing from my car?
http://forums.pelicanparts.com/uploa...1226788727.jpg
More pics in this thread;
http://forums.pelicanparts.com/porsche-911-technical-forum/409888-do-i-need-replace-my-targa-seal.html
Thanks,
Paul.
Paul K 11-15-2008 04:58 PM
Update:
I got both old seals off. I test-fitted the new seal, and it barely stays in the channel across the top of the windshield, and feels like it might fly out at speed. I have read that glue should be used on the door seals, should I glue the whole thing? Also, I test-fitted the targa top, and now have a big gap across the front. I suspect this will cause a lot of wind noise. Can I adjust the top forward or should I put the second seal back in there?
Pics;
http://forums.pelicanparts.com/uploa...1226797008.jpg
http://forums.pelicanparts.com/uploa...1226797037.jpg
Thanks in advance,
Paul.
HarryD 11-15-2008 05:09 PM
Paul,
It looks like you need to adjust your top forward. How does the rear fit?
Paul K 11-15-2008 05:12 PM
Harry:
It looks to me like it sits too low and too far back in the rear. You can (kinda) see it in my second pic in the last post.
Thanks,
Paul.
