Cabriolet
OK does any know how the Cabriolet GURU around here is or if there is a good book on sealing them up. As with a lot of these I have a leak around the front edge at the door frame. I've run out of good ideas.
Thanks Steve
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html Last edited by Laneco; 11-15-2008 at 08:31 PM.. |
Used Up User
Someone told me that he just added some 1/4" foam insulation behind the body seal at the top. Only a couple of inches. I didn't try it, though.
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
83 CHECKER
By the word leak do you mean water accumulating on the floorboards, or the drip that falls on your sleeve durring a heavy rain while driving. I have an '83 cab, never had a water leak issue, it is actually quite sealed compared to the british cars I've owned, I had a '90 corvette I would equate it to, both being convertibles, no water pooling inside of car, but if driven durring a heavy rain the occasional drip on the sleeve is expected. The "waterproof" cloth tops do absorb alot of water, I think if I was to do it over again I would opt for the less expensive "godforbid" brand.
'83 911SC CAB '90 ZR-1 '68 TR-250 |
I have a leak at the right front. the top seals up well, but you most likely need to change the rubber seal at the leading edge of the top. Mine has a cut in the rubber that causes the leak.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Cabriolet sealing
What I have is an 80' Cab conversion this was done in Europe before coming over. There is more than a drip but it's not poring in. I bought new side seals but they don't fit well and don't look the same as the one's on the car now. So any advise is helpful.
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
bump
thanks
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
Cab
The alignment of the window and wing glass seem to be correct. The issue looks like the seal it self so I replaced them and they don't seem to fit right. I was hoping to get some guidance as to how it fits because when installed I can't close the top?
