rodoredas's Avatar
CIS to PMO Carburetor upgrade
Hi guys - no luck on the aussie forum --- , anyone had any experience in upgrading a 2.7 CIS to the PMO Carburetor's at www.pmocarb.com, I'd be interested to know any feedback.
cheers
Shane
1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500
1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158
Old 11-16-2008, 03:24 AM
ael911's Avatar
Here's my experience and I only wish I did it sooner.
PMO conversion, it's done...almost
'75 911S Silver Anniversary #164(Formerly JTO's)
Rebuilt 2.7 with full ARP, 9:1 CR.
SSI, GHL, ER polybronze bushings, finned oil lines.
Lowered and corner balanced. CIS retired, now PMOs!
'65 912 slate gray sunroof (driving project)
Old 11-16-2008, 06:15 AM
Been doing these since 1977 with Webers, now PMO's,....
Aside from the decreased (naturally) fuel economy, its really amazing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-16-2008, 10:12 AM
rfuerst911sc's Avatar
I have a 83SC that went from CIS to 46mm PMO carbs and I love them. And I can get 17-17.5 mpg on the highway which isn't too bad. But that is a fair trade off for the sound and throttle response and as a added bonus it makes a 911 engine compartment look the way they are supposed to.
Old 11-16-2008, 02:04 PM
rodoredas's Avatar
Thanks guys, sound like I should start saving, Aussie dollar at around 65cents makes this rather expensive at the moment, one day. Interestingly an advanced search on PMO I did before posting this found nothing. Nice photos and thread ael911.
cheers
Shane
Old 11-16-2008, 02:16 PM
moneymanager's Avatar
Did my 2.7 three years ago, junked the CIS and added PMOs. They are wonderful.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 11-16-2008, 03:46 PM
AutoBahned
RWebb's Avatar
- weird - same for me; used PMO in caps - 0 hits
Old 11-16-2008, 03:54 PM
HarryD's Avatar
cheers
Use PMO* as your search term for PMO. You will get the threads you seek.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-16-2008, 04:49 PM
rodoredas's Avatar
Other than the carby upgrade and maybe fuel pump upgrade is there anything else that is required when you do this. Can we just bolt on the PMO's without changes to cams, exhaust etc. Understand these may be worthwhile but I am assuming they are not necessary.
Shane
Old 11-16-2008, 05:23 PM
Shane,
I did my 2.7 a couple years ago. As I live at 5,500 ft. elevation, I wanted the performance lost to thin air. I added 9.5 JE pistons and Solex cams. This 911 is my race car so I also changed the transaxle to a 7:31. The car came alive on the track running down 3.0's and 3.2's.
Just changing the carbs without at least changing out the CIS cams, will not impress.
It took me about a year to learn everything I needed to know to really get the best out of the carbs. A person familiar with the Webers or PMO's can bring them into top tune quickly.
About the fuel pump; PMO makes a simple reliabe regulator that uses your existing CIS pump. It uses both the supply and fuel return lines. A pressure guage is part of the system so you know you are at 3.5psi. I recommend it.
Again the key to success is you or someone close to you that is familiar with carbs.
Doug
Was 2.7racer.
'76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car.
'85 3.2 stock, Orient red, comfy street car.
Old 11-16-2008, 05:47 PM
AutoBahned
RWebb's Avatar
- not required for lotsa fun, good sounds and a few hp
BUT - the whole character of the engine and its ability to make power is due to the cams.
Old 11-16-2008, 11:05 PM
rodoredas's Avatar
thanks again guys, heaps of good info.
cheers
Shane
Old 11-16-2008, 11:20 PM
