-   -   X-post from Turbo forums, how to hook up RPM to Innovate SSI-4 (http://forums.pelicanparts.com/porsche-911-technical-forum/441655-x-post-turbo-forums-how-hook-up-rpm-innovate-ssi-4-a.html)
equality72521 11-16-2008 04:50 PM
I have an Innovate SSI-4 and LC-1 combination to be used for measuring AFR, RPM, Boost, Volts, and eventually crank position. I've got everything figured out except how to hook it up to measure RPM. Has anyone done this? I need to pick up RPM+ and RPM- to input #1 on the SSI-4. Would I simply tap the tach wire and the ground wire at the CDI?
