AC ok in 87-89?
I'm planning an RSR backdate but want good AC. The last (road) 911 I had was a 93 964 and the AC was great (was R12). As the TRE backdate kits are for pre-90 only, is the earlier AC ok? How about 84-87? I am pretty sure SC AC will require a complete overhaul to be effective. I know overall good/leak free condition is essential either way but I don't want to have it as a separate project if I don't have to.
If it means replacing the main components with modern equivalents so be it, just would like to have an idea up front. Thanks!
Gary R. |
If you want good AC in a Carrera you will need to upgrade. Assuming everything was perfect in a stock system it's only so-so.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
for a long time I thought 911's ac is simply a piece of S. because I had spent much time and $$ on repairing/recharging without good result. But recently, after reading many successed stories on this board, I gave it another tried and it turn out well. If you expect it to be as well as a modern car's ac, then the answer is no, not even closed. But it can be well enough to survive in SCal summer. On a 100 degree day, it can blow around 60 or 65 at the vent. On 89 degree day, I got around 40+. Some days, I got it down to a little below 40. I am ok with it now, even recharge once every summer.
Fat butt 911, 1987 |
Thanks. In the 964 the AC was as good as most modern cars, and I guess I may as well plan on a complete update of all AC components when I build her. Main thing is to get a car that hasn't been hacked up and has everything in place, or I guess I can run with the windows down...
Gary R. |
Even if you spend some $$ on it to get the temp down, there still is woefully insufficient volume.
todd 89 targa |
Almost the whole past summer, my 911 AC's temp at the vent is the same or sometimes even better than in my Lexus when it's turn up 3 clicks. But I felt freezing in my Lexus while felt only cold in my 911. I think it is the volumn of air blowing toward you is the key.
I think investing in AC in 911's is really a matter of where you live and how much you use your car. If I live in AZ and I'm commuting with it, AC is a must. If you live in CT and you can handle the dozen or so days in the summer when it gets hot, I would leave the AC alone or even remove it. I've had mine out of my 89 for 5 years and it doesn't bother me a bit. Besides, spending more money to add weight and rob power from you sports car just seems counterproductive.
I live in the NorthEast (NY/NJ/CT) and can tell you the
AC in my 993 was used from April to October... To think that 'someone' paid $47K for my 87 coupe back then and not get a proper working ventilation system is pathetic. I will do the upgrades one day though... the point is, I should have to ! One of the main reasons I bought my 993 was because of the superior AC / Ventilation system. The heat literally comes on it 3-5 minutes. Defroster works perfect!
87 911 97 993 prior p-cars: 76 912E 85 targa |
Thanks for the replies, anyone happy with an updated AC in a mid-year 911? Figure new compressor, lines, and dryer/condensor (what else?)..
Gary R. Last edited by GaryR; 11-29-2008 at 05:47 AM.. |
Recreational User
I grew up in Wilton, CT and it gets downright hot and muggy in the summer months.
To upgrade your A/C, you may need additional condenser units and a better evaporator. |
