viper4490's Avatar
car wont turn on??
82 911
I was driving yesterday and i was at a high rev and when i shifted It felt like my car had more power. I put premium gas in it that day. I usually put the plus.. Anways my car cut off, strated somking, I opened the hood and I smelled gas. The car turns but it seems like its getting no spark..Now today when i turn the igniton theres this loud noise in the rear that I never heard before, like somthin turning on like the fuel pump I guess?? I never heard it that loud before.. And now its not doing wit it did last night, I dont think the engine is turning now...did i blow up the engine?? there is no oil splatter anywhere so I guess i didnt....anyone know whats wrong???
Old 11-14-2008, 11:44 AM
'79 911SC TARGA
CROWSC's Avatar
Sounds like your fuel pump is sucking air. I ran out of gas not to long ago,
and heard a noise that I had never heard before, just before running out.
I got out and checked it and it seemed to be the fuel pump.
You might have a fuel leak, that is causing air to get to the pump.
Good luck.
CROW
'79 911SC TARGA
'05 BMW 525i
'98 HARLEY HERITAGE SPRINGER
'11 Ford Edge
Old 11-14-2008, 04:02 PM
ruf-porsche's Avatar
Originally Posted by viper4490 View Post
82 911
The sound is not the fuel pump. The fuel pump is located in the front of the car. If the engine is not turning over, your battery is dead..
Old 11-15-2008, 09:37 AM
viper4490's Avatar
thanks for the info guys. Does anyone know what the loud noise is in the rear though? its on the left side of the engine on the wall- I think the sound is coming from. And what I ment to say is that I smelled gas in the engine bay.
Old 11-16-2008, 01:28 AM
rnln's Avatar
if you have gas leak, and the engine is not running anymore => you can't check for leak. Is it posible it leaked too much and you have no more gas now?
If you can manage for the engine to run again, check carefully on gas hoses behind the intake and air box, near and along the firewall, around all the gas hoses. I actually sticked my hands back there to feel for wetness while the engine is running. Becareful on the fan and belts.
Fat butt 911, 1987
Old 11-16-2008, 01:34 AM
DanielDudley's Avatar
82 911
A click,click,click,click noise would be the starter solenoid trying to engage. I am assuming that you didn't way over rev the engine. You may have two problems, lack of fuel and dead battery from trying to start the car up.
Find out if you have a fuel leak, as they can be fire hazards. Then you can charge the battery or jump start. We do not want to look at pictures of a burnt out shell.
Old 11-16-2008, 03:46 AM
T77911S's Avatar
you could have a rocker shaft that has come out or something to do with the valve train has come lose or broken. pull the valvle covers on the left side and check. start with the intake, you dont have to drain the oil to do that one.
if it is the exhaust, you could have hydro lock.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-18-2008, 05:46 AM
