-   -   Any good tricks for removing speed and reference sensors from the mounting bracket? (http://forums.pelicanparts.com/porsche-911-technical-forum/442105-any-good-tricks-removing-speed-reference-sensors-mounting-bracket.html)
mthomas58 11-19-2008 09:45 AM
I've got 1 sensor out and 1 stuck....REALLY STUCK. I will be replaceing them both so no need to salvage. I've tried PB Blaster and heat and no luck so far. Any good tricks before resort to I tearing up the offending bastige? BTW the one that's stuck is not the one protected by a tube.
JeremyD 11-19-2008 10:02 AM
I stick mine in a vice and banged with a hammer. I knew I was going to replace anyway.
KTL 11-19-2008 11:33 AM
Mangle the heck out of it. It doesn't matter since you're planning to replace.
charlesbahn 11-19-2008 12:50 PM
Stop! One of the sensors is in a sleeve and if you bugger up the sleeve you have to also replace the mounting assembly
edit- oops sorry- started typing before I finished reading.
crashr 11-19-2008 01:36 PM
I just did this job and had the same problem. The one without the sleeve (Speed Sensor) just wouldnt come out. I took a hack saw to it to get past the soft cover, then I hit it from the back side with a punch and hammer to free it up.
I found I couldnt get the new sensor in either so I used the sanding bit on the dremmel to clean out the corrosion that was stuck to the walls of the mounts.
Regapping the mount was the biggest pain, as the job requires at least 3 arms where only 1 will fit. Obviouslly the idea to put a 0.8mm washer on the end of the old sensor didn't work since I had destroyed it. I used a feeler gage which i taped tight into some neednose plyers. Be sure not to drop it into the bell housing of the transmssion!
charlesbahn 11-19-2008 02:21 PM
Definitely easier if you do it with a washer glued onto an old sensor. If you need one let me know I kept it and I'll loan it out as long as it is returned.
Charles
mthomas58 11-20-2008 05:48 AM
Answer is there is no easy way to remove the sensor......21 years of corrosion and it was totally fused. I twisted off the plastic top and cut off the bottom of the sensor with a cut off wheel. There is a magnet rod in the core of the sensor that is encased in plastic that runs the entire length of the sensor. I was then able to punch out the magnet core then had to chip out the plastic and dremel out the corrosion. No way around it - it must be "mangled-out"! So much for my hope that John Walker would swoop in with one of his easy fix tips ;)
http://forums.pelicanparts.com/uploa...1227188539.jpg
my journey continues ........ (targeting the week of Christmas/ New Year to complete the swap)
http://forums.pelicanparts.com/uploa...1227188791.jpg
DRACO A5OG 11-20-2008 09:36 AM
Caution! DO NOT TWIST in the new Sensor. It will break the internal filament liken to a stuck light bulb. If you break the filament your car will not start. Ask me how I know.
+1 there is no easy way to take out that Speed Sensor. The housing needs to be removed then the old sensor mangled out. Carefully press in the new sensor then use the moded feeler to get the proper gap.
Of course easier with the engine out but no need.
BoxsterGT 11-20-2008 09:48 AM
The sensor mount is expensive.
Anyone making a billet replacement?
Len
mthomas58 11-20-2008 09:58 AM
Len
I would think a dismantler would be the way to go to replace a buggered mount.
