'70 911E
1970 E Odometer
my odometer stopped working recently, the speedo's OK, is there any thing I can check or do or should I look for a replacement? Thanks, Rick.
Old 04-07-2011, 01:51 PM
Send a message via Skype™ to Porboynz
I guess you tried resetting the trip meter in case it was jammed. Pull it apart, its probably a gear stripped but maybe a pin has come loose and just needs refitting. Its like an old alarm clock in there, fairly simple.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 04-08-2011, 09:00 PM
