-   -   Brembo calipers question.Help please! (http://forums.pelicanparts.com/porsche-911-technical-forum/442191-brembo-calipers-question-help-please.html)
BART'S 911 SC 11-19-2008 06:43 PM
I have set of those calipers.Does anybody knows what kind of adapters do I neeed to fit them on 78 SC?What model of calipers are those?What kind of rotors would I need for it?What is the best rear brake upgrade for SC?http://forums.pelicanparts.com/uploa...1227148964.jpg
http://forums.pelicanparts.com/uploa...1227148993.jpg
Steve@Rennsport 11-19-2008 10:34 PM
Those are Brembo GTP-L brakes which use a 313x28mm floating front rotor assembly.
One uses the matching rear caliper and similar sized rotor for the rear that retains the E-brake.
Both front & rear calipers are Lotus applications with properly sized pistons to maintain proper brake bias.
