-   -   8X16 Fuchs in front (http://forums.pelicanparts.com/porsche-911-technical-forum/442242-8x16-fuchs-front.html)
Geronimo '74 11-20-2008 07:03 AM
8X16 Fuchs in front
Is this possible?
I'm buying a set of 7 and 9 Fuchs wheels and I want to switch with the 7 and 8 I have now.
Can I put 8s up front? (regular carrera flares)
I don't want to use a lot of neg camber. It is not a track car.
thanks guys,
IROC 11-20-2008 07:12 AM
I think the only Fuchs 8s that will work are the special offset 951 8" Fuchs. Regular 8s won't work.
You have the 8s now? Heck, bolt 'em on and see what happens.
JeremyD 11-20-2008 07:29 AM
Originally Posted by Geronimo '74 (Post 4314557)
Is this possible?
thanks guys,
I have 8's and 9's - the 8's in the front are 951 version part number (951.362.117.00)
http://www.pelicanparts.com/pmpre/im.../TRACKPIC1.jpg
Bill Verburg 11-20-2008 07:59 AM
Is this possible?
thanks guys,
No question about it, Use the 7 & 9 for a street car
the 944/951 8" Fuchs Jeremy mentioned can be used, but it's not a comfortable fit, especially w/ street alignmenst, the o/s is just a tad low @ ET23.3(same as the 7s)
To use an 8 on the front you will want ET25 - ET31
Geronimo '74 11-20-2008 08:15 AM
7 and 9 it is then.
Thanks guys
