Does 10,5:1 JE Pistons will work w/single plug
I plan to do a cheap upgrade of my 2,4T : going with JE pistons, S cams and Weber 40. I don't really know if it's better to choose the 9.5 or the 10.5:1 compression ratio ?? any experiences ?
JD
65 coupe, Dolphin gray #1506
70S coupe, Blood orange #1436
R Gruppe #647 ; S Registry #1666
Old 11-20-2008, 07:04 PM
DanS911's Avatar
I have just completed a rebuild of a 3.o with 10.5/1 J&E pistons and 46mm Webers and single plug heads. The motor was in a friends car before and it ran like stink. I hope the end result is the same for me!
Dan
'86 911 Targa Driver
'76 911 Targa 3.0 Track Toy
46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky)
Old 11-20-2008, 07:11 PM
Wer bremst verliert
JohnJL's Avatar
You're on the edge there. My 10.5:1 JE's measured out to 11.2:1!
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-20-2008, 07:27 PM
DanS911's Avatar
Wow how the heck does that happen?
Dan
Old 11-20-2008, 07:30 PM
Warren Hall Student
Bobboloo's Avatar
It'll work but only if you use race gas. If you want to use pump gas then you need to go with the 9.5:1 set.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-20-2008, 07:37 PM
juicersr's Avatar
Sure, IF you are able to fill you tank with 100+ octane gas everytime you fill up, or don't mind worrying constantly that your newly rebuilt motor is going to detonate if dont. I researched this a lot before starting on my rebuild. Gas quality is prolly going to get worse, so if you are not going to go twin plug, or use race gas every expert on this board that i read in threads and corresponded with said keep the compression lower than 10.5:1. I actually decided to go with 9.8:1 JE's with custom domes due to the fact that i have an EFI system with Wideband o2 that will allow me to make sure the AFR stay right where i want. Good luck with your build.
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
I wonder if a 3.4 with low compression ratio needs twin plugging?
Heard from a friend that a Japanese specialist offers rebuilt engines with displacement up to 3.6 without twin plugs that do not detonate. Dunno about the C/R but is there any other ways to prevent high C/R engine from detonating besides twin-plugging and high octane gas?
'87 3.2 Targa
Old 11-20-2008, 08:27 PM
Warren Hall Student
Bobboloo's Avatar
1. Flat top pistons with the spark plug placed in the center = shorter flame front = less advance needed = less chance of detonation.
2. You could always just retard the ignition but then that kind of goes against what you were trying to achieve in the first place with a higher C/R.
Bobby
Old 11-20-2008, 10:00 PM
Warren Hall Student
Bobboloo's Avatar
JD
In all truthfulness. The cheapest upgrade for your 2.4T is to replace it with a bigger motor. Unless your motor was recently rebuilt and everything is in spec this cheap upgrade will end up costing you $10k large. Many owners of these mag case motors go in for a cheap $500 reseal to fix some oil leaks only to end up 10 to 12k lighter in the wallet. If your motor is running well you might just want to leave it alone.
Bobby
Old 11-20-2008, 10:10 PM
AutoBahned
RWebb's Avatar
yeh - put the spark plug in the middle!
Old 11-20-2008, 10:13 PM
onboost's Avatar
Yeah, I caught that one too...
RGruppe #180
Old 11-21-2008, 07:14 AM
MBruns for President
JeremyD's Avatar
I have a 3.4 with single plug - I have decent gas in Florida too though
Old 11-21-2008, 07:24 AM
