| GT911 |
11-20-2008 06:10 PM |
Planning to put a 3.6 top-end on a 3.0 bottom end
Looking for a little advice or warnings of what I might be getting into. I realize there will be some machine work involved.
I have a street driven ’81 911sc with a 3.0, and the typical upgrades, steel head studs, 964 cams, and hydraulic chain tensionors. I have the engine out to begin a rebuild with new bearings, chains, seals etc…, but then begins the unconventional upgrades I have a ’90 3.3 turbo 115 amp alternator/fan that is a direct bolt in, I have a set of 964 heads, but plan on using the 3.0 cam towers and a 964 intake manifold and the early heat exchangers that will let it all breath. I realize there is some machine work required to make the heads fit, but that should be fairly easy for a competent machinist.
I’m looking for a 964 fan shroud that will fit the head pattern, and I’m also looking for an early air duct that will let me cut a square hole in the 964 shroud and bring air over to the oil cooler.
I’m also building a megasquirt EFI control system with an EDIS crank trigger ignition for the twin plug heads.
I would like to add some displacement, but not sure what the best options are to get the best bang for the buck.
I know your 98mm Max Moritz setup is a very easy upgrade, but what’s the possibility of adding the 964 100mm cylinders? I’m aware of the different stud spacing, but I also have read of members of the pelican community machining the 100mm cylinders, with 90mm stud spacing to fit the 86mm studs, and I already have to do this to the heads. Matting surfaces of the heads and cylinders would be easier with 964 cylinders. The next challenge would then be the pistons, I see the wrist pins are different, but could my 22mm rods ends be machined to 23mm? I certainly don’t want to save money on cylinders only to spend a fortune on pistons. I’m really at the far ends of my budget, but I don’t plan on ever going back into this so I really want to get the best bang for the buck as I can. Any advice is greatly appreciated.
