Planning to put a 3.6 top-end on a 3.0 bottom end
Looking for a little advice or warnings of what I might be getting into. I realize there will be some machine work involved.
I have a street driven ’81 911sc with a 3.0, and the typical upgrades, steel head studs, 964 cams, and hydraulic chain tensionors. I have the engine out to begin a rebuild with new bearings, chains, seals etc…, but then begins the unconventional upgrades I have a ’90 3.3 turbo 115 amp alternator/fan that is a direct bolt in, I have a set of 964 heads, but plan on using the 3.0 cam towers and a 964 intake manifold and the early heat exchangers that will let it all breath. I realize there is some machine work required to make the heads fit, but that should be fairly easy for a competent machinist. I’m looking for a 964 fan shroud that will fit the head pattern, and I’m also looking for an early air duct that will let me cut a square hole in the 964 shroud and bring air over to the oil cooler. I’m also building a megasquirt EFI control system with an EDIS crank trigger ignition for the twin plug heads. I would like to add some displacement, but not sure what the best options are to get the best bang for the buck. I know your 98mm Max Moritz setup is a very easy upgrade, but what’s the possibility of adding the 964 100mm cylinders? I’m aware of the different stud spacing, but I also have read of members of the pelican community machining the 100mm cylinders, with 90mm stud spacing to fit the 86mm studs, and I already have to do this to the heads. Matting surfaces of the heads and cylinders would be easier with 964 cylinders. The next challenge would then be the pistons, I see the wrist pins are different, but could my 22mm rods ends be machined to 23mm? I certainly don’t want to save money on cylinders only to spend a fortune on pistons. I’m really at the far ends of my budget, but I don’t plan on ever going back into this so I really want to get the best bang for the buck as I can. Any advice is greatly appreciated.
GT911 81 911 SC |
sounds like a nightmare. buy a 3.6.
Senior Advisor
im with John, 3.6 has all the goodies you need. and stay with the 915 tranny. that's what l want when my engine craps out. However, that should take place sometime around 2023!!!! i
08 Cayenne Turbo |
Gary Kozun 83 911SC Cabriolet Last edited by mytoy; 11-20-2008 at 10:04 PM.. |
AutoBahned
"there will be some machine work involved..."
why do you want to spend 3x what you could buy a complete motor for?? |
MBruns for President
http://www.lnengineering.com/
Talk to charles - he'll give you a good idea on costs and reasonableness. But I agree with the others - it will probably make more sense to go with a 3.6
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Not only should you jsut go with the 3.6L...but you should also pass those 964 cams on to a highly deserving Texan, like myself
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
