-   -   What is the lug pattern for a 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/442396-what-lug-pattern-911-a.html)
jwerion 11-20-2008 08:56 PM
Hello,
I have searched the forum for this info but can't find it. I need to know what the 5 lug bolt pattern is for the 911's with trailing arms. Any help would be greatly appreciated.
efhughes3 11-20-2008 09:00 PM
You need to sharpen your search skills
5 X 130mm
Dantilla 11-20-2008 09:02 PM
And just so you know, no other manufacturer uses the 5x130 pattern. The wheels must be Porsche-specific.
450knotOffice 11-20-2008 09:02 PM
5 x 130
jwerion 11-21-2008 01:45 PM
Ed,
Thank you all for the information
Ed what terms did you use in your search I tried 5 lug bolt pattern, 911 lug pattern, porsche bolt pattern, 911 hub pattern, etc.
crustychief 11-21-2008 02:39 PM
porsche 5 bolt lug pattern wheel spacers
Zeke 11-21-2008 02:56 PM
I love the search. I used the above recommendation and here's what I got:
"Sorry - no matches. Please try some different terms.
The following words are either very common, too long, or too short and were not included in your search : 5
So, you can't use "5". How many people have you seen type "five"??
crustychief 11-21-2008 03:03 PM
I used google.
Zeke 11-21-2008 03:09 PM
Ah, brilliant!
tangerine911S 11-21-2008 03:22 PM
I agree that the search function is very limited, especially to many Porsche related terms (rsr, sc, rs, st, r, and numbers). Why wouldn't it just find exactly and only what you type in, no matter how small or numeric?
Never thought of google for a pelican search. Good idea.
efhughes3 11-21-2008 03:45 PM
I knew the answer, so I didn't have to search...but I think bolt pattern is the term I typically see used-that may provide results.
You can use a * as a wildcard to fill out the three character requirement, for at least one of the spaces. Such as H1* to look up anything on H1's.
