-   -   Shift knob Question 85' Carrera (http://forums.pelicanparts.com/porsche-911-technical-forum/442512-shift-knob-question-85-carrera.html)
rgdtoo 11-21-2008 02:31 PM
Following the OEM manual to remove my shift knob I destroyed it as the top portion was not removable as stated. :rolleyes:
Are they screw on type, glued on ~ what??? :confused:
Any help greatly appreciated! :D
Thanks,
rgd-out
Ps. IMHO not enough smilies used on this forum.
the 11-21-2008 02:34 PM
An 85 shift knob is one piece.
It is held on to the shifter by the use of a crush sleeve and press fit.
rgdtoo 11-21-2008 02:40 PM
Sounds like it is a operation to remove it, cut, file etc...
Any helpful suggestions. I am wanting to install a Momo before Mon/Tues track events.
the 11-21-2008 02:44 PM
Typically, people get something underneath the shift knob, like a large open ended or adjustable wrench, and then hammer it up.
You could wrap it with a rag or something to try to protect it. But they can be pretty tight and a lot of people seem to end up destroying them.
If yours is wrecked anyways, there are lots of ways to remove it, a large pair vice grips would have it cracked off in seconds, for instance.
rgdtoo 11-21-2008 02:50 PM
Thanks for the info.
gtc 11-21-2008 04:46 PM
Just pull on it like crazy, and try not to punch yourself in the face when it finally comes off the gear lever.
4flyboy 11-21-2008 04:49 PM
Yup
lol. Now that's good comedy..............I've done it.
Scott
left a mark too.
gtc 11-21-2008 04:52 PM
Yeah, I hit myself in the nose the first time. Hurt like a mother...
