sway bar upgrades
hi everyone,just need some input from the baord members,i have a 72e with stock front and rear sway bars, i am thinking of a 21 rearsway bar and maybe 22mm,front this would be used for on road no track with precise handling,at least thats what i want,is this a good idea?open to all suggestions,thanks frank
Be prepared for a jarring, pitching ride; moreso than with stiffer torsion bars for an equivalent decrease in body roll.
Sway bars link both sides on an "axle" so if one wheel goes into a pothole or over a bump, the other will react with it. With independent torsion bars, even stiffer ones, there will be more street compliance for uneven surfaces. If you are on a smooth track, stiff sway bars are no problem, though. Adjustable sways can be a useful tool to fine tune a chassis for different tracks or autocrosses. |
| All times are GMT -8. The time now is 08:23 PM. |
