how do you remove a 82sc center reflector
anyone have a trick to remove a rear center reflector (clip style) from a 82sc without destroying it? please tell me.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Above the muffler,theres a heat shield held in place with some screws.Remove these and the shield and this will give you access to the area behind the reflector.The clips which hold it on can be eased off using a long screwdriver,take your time with these as you will want to re use them. Cant remember how accessible this is as I had the bumper off at the time.
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
Retired Member
On my car I had to remove the muffler to see the heat shield. My reflector had small nuts holding it on the car. I think they were 5 mm. nuts.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
