Car Dies Over 4000RPM
Hello all. I have a question/problem. This morning on my way to work any time I went close to/over 4000 rpms my car died. It started right back up and drove fine as long as I kept the revs low. The car was at proper operating temp as well. Then right before I pulled in I was at a light and the car died again. Once again it started right back up and drove fine. The only 2 things that changed recently are: I filled up the tank on Sat and I swept out the garage yesterday-not too much dust though. Any help or insight is very much appreciated. Thanks in advance.
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 11-24-2008, 06:21 AM
Evolved
Mo_Gearhead's Avatar
Sounds like a possible fuel starvation problem.
I'm not familiar with your year car.
Does it have a fuel filter (in-line)? At the tank outlet?
I'd start there.
Don't fear the reaper.
Old 11-24-2008, 06:35 AM
tedder's Avatar
whats the status of your charging system? When my alternator started to go it wouldn't idle (not enough juice) and wouldn't run well at hight RPM (not enough juice)
08 Porsche Cayman (base) <- My hands are too big to need to compensate with an S
86 911 Coupe <- WOOT <- sadly gone since late 2014
Old 11-24-2008, 06:37 AM
i second the fuel suggestion.
84 R5 T2
04 Suby Outback
"it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill.
Old 11-24-2008, 06:39 AM
Did it recover on its own or did you actually have to start it?
Was the engine under load or just the fact you hit 4000 rpm?
If no to both I'd look inside the distributor to see if the repositioning mechanism is working assuming this is a DME car.
Rick
88 Cab
old style head temp sensor still? check the fuel filter for sure.
206 637 4071
Old 11-24-2008, 06:42 AM
Hello. The car was under load and approaching 4000rpms when it died. I had to restart the car myself.
Chris
Chris
95 993 C2
Old 11-24-2008, 06:43 AM
I'm not sure about the head sensor type. Please don't kill me but where is the fuel filter? Thanks.
Chris
Chris
95 993 C2
Old 11-24-2008, 06:49 AM
Also- I was qondering if this could be the DME or the fuel pump relay?
Thanks,
Chris
Chris
95 993 C2
Old 11-24-2008, 08:47 AM
