-   -   '79 911sc initial CO setting (http://forums.pelicanparts.com/porsche-911-technical-forum/443012-79-911sc-initial-co-setting.html)
jerkan 11-24-2008 03:13 PM
Anyone know the procedure for doing a preliminary setting on the mixture screw for a 79 911sc? I seem to have read one time that there is a way of dialing in a rough setting by turning in the screw until the injectors start to spray and then backing off a turn or so.
thanx
Jim Williams 11-24-2008 03:50 PM
That's only a starting point, and only if you've replaced a fuel distributor or and air flow sensor. If the engine runs at all, this is too basic an adjustment, and you will lose a lot of ground. The factory manual calls out a number of turns or part turns for this procedure and I can't recall if from memory, but I can look it up.
Gunter 11-24-2008 03:57 PM
NO, no......jerkan:
Be careful with turning the mix adjust screw any which way.
The mixture is adjusted after the engine runs.
The injectors with K-Jetronic spray continuously that's why it is called CIS (Cont. Injection System)
Get a book on CIS and also get the Bentley SC Repair Manual.
If you dismantled the metering body, refer to the initial setting of the airflow sensor plate .
jerkan 11-24-2008 06:08 PM
I have dismantled the mixture control unit. I have all the manuals, including the bosch fuel injection guide, however, nothing tells me how to set the initial setting before i attempt to start the car. I just need the rough setting to get me in the ballpark so i do not blow up my airbox on the initial start.
john walker's workshop 11-24-2008 06:13 PM
if it's the same fuel distributor that was on there originally, nothing would have changed. if it ran before, it will run again. you may need an exhaust analyzer to get it right on though.
Paulporsche 11-24-2008 06:23 PM
Do you have an airbox popoff valve?
jerkan 11-25-2008 05:28 AM
popoff valve installed.
I changed alot of settings when I rebuilt the car including the mixture screw. I just want the thing to be close when I start it up.
Paulporsche 11-25-2008 05:39 AM
Can you try to put the screw back to about where you think it was prior to your work?
At least the popoff valve should prevent airbox explosions if too lean. If you are way off , the engine probably won't even start.
Are your AAR, AAV and WUR all within spec?
I was fooling w/ mixtures & WURs this summer. At times both were way out of spec, but I was still eventually able to get started, and any leanness was handled by the popoff valve popping. Richness was quickly apparent via smoke, smell and idle hunting.
As Gunter said, make sure the sensor plate is @ the right height for starters.
Gunter 11-25-2008 10:06 AM
Check out page 240-4 and 5 in the Bentley: Basic settings.
It gives you the sensor plate height in the rest position.
T77911S 11-25-2008 11:00 AM
he is wanting a preset for the mixture like you would preset the mixture after rebuiling carbs.
if he took the AFM apart and removed or turned the mixture screw, he wants a basic initial setting to help get it started without have to crank it for hours.
