sagacis's Avatar
Question Mystery wire connectors
I was cleaning up the engine bay to do a valve adjustment, when I noticed this pair of wires. They had obviously contacted and burned into each other at some point. I can't tell where they should go. Those are barrel connectors on the end. The ends were tucked down under the warm up regulator. One is red/white or red/yellow. The other is brown.
The P.O. had removed the cruise control unit in the rear. Could it be from these?
Either I'll replace the ends and connectors, or I'll just cut and tape.
So, what are they?
Mark Arvidson
1981 911SC Targa
Old 11-07-2008, 01:37 PM
sudo apt-get purge 930
equality72521's Avatar
A lot of people have asked about those and I've never seen an answer. They used to be in a black plug that is apparantly missing on yours. That's why they made contact with each other. One side is hot and the other is ground. Most cars I've seen had this plug taped back on itself to the harness unused. I suspect this is the case with yours except the plastic plug is missing. I'd tape or heat shrink the ends and not worry about them.
--clutch-monkey
Old 11-07-2008, 03:35 PM
Here you can see what the plug looks like.
--clutch-monkey
Old 11-07-2008, 03:38 PM
TargaRob's Avatar
Those look like the wires that go to the heater blower fan.
Rob Owen
- 1980 911 SC Targa
911 Design
Parts Manager
Old 11-25-2008, 10:02 AM
Happiest when Tinkering
gsmith660's Avatar
+1
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-25-2008, 10:42 AM
Tags
wiring engine bay
