(When stopping the car-not running)
When the backpart is lower then the front, I normally get a oil leak from the motor at the right side. If the back part is higher then the front, there are no oil leak. Any with some interesting ideas whats wrong? |
Information Junky
an oil return tube. . .maybe? The ones between the head and case.
------------------ '81 Platinum Metalic SC Coupe |
I suppose that it could be a valve cover that is unevenly tightened and loose at the rear so that oil pools and drips out when parked nose up. Or maybe its the right chain housing cover.
------------------ Rod Walter '88 911 coupe |
