misfire then ran ok - need Stabil + Techron?
my 89 3.2 has been sitting not being used much over the last 5-6 months...
The other day I went to take it out and blast up the road I like... to heat up the engine and clean out old gas.. there was a misfire, right at startup, for about 1 minute and then went away. I figure it was a gummed up injector... Anything wrong with running Stabil and Techron for the time being? I don't think I have a smog check coming up... I've read on here to not risk CA smog check with Stabil.. so I'll follow that if/when the time comes. Thanks. |
I'd go with the Techron...then a long drive to run it through, clean things up, and empty the tank.
Don't do any Stabil until after the smog check. But after the check, yes, if you're going to have the same gas in the car for 6 months, it wouldn't hurt.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
Detached Member
Your in Cali, run the car once in a while. Even just start it up and let it idle and warm up. My car had misfires or hesitation when I first bought it. I checked O2 sensors, reference and speed sensors, all fine. In the end, a little techron and using it fixed the problem.
Hugh |
Injectors like to stick shut when you don't run the car for a while. I would just run it. There is no need for any additives or cleaners IMHO.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
SeaFoam
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
