interior switches on a79SC
Is the toggle switch above the ignition switch used for the heated mirror? If so which position is off. the switch pressed in on the driver side or the passenger side.
Rick T |
Keepin' it Simple...
That is a spring loaded switch that is used for opening/closing your sunroof.
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
The mirror heaters, I believe, are activated when you pull out and turn the rear defroster knob.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
That switch toggles between the electric mirrors. They use the same switch on the door panel for adjustment.
