Jupiter 911
bklyn's Avatar
AC -vs- more hp?
Gents, I realize if I remove my AC unit from my 1987 3.2 Targa I can get more hp,s by removing the weight. But living in Florida its 80 today, two days after Thanksgiving. Would I benefit any by just removing the belt?
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 11-29-2008, 10:45 AM
At the track = great day
ChkbookMechanic's Avatar
You'd add a little bit of power by not having to drive the a/c unit.. maybe 2 - 5 hp. And really, just removing the compressor isn't going to save you that much weight. You need to remove all of the A/C system to really get a nice weight savings imo.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 11-29-2008, 11:09 AM
Jupiter 911
bklyn's Avatar
2-5 hp might be worth the belt removal from time to time.
Old 11-29-2008, 11:13 AM
If the compressor clutch is not energized (A/C is switched off) the turning belt and pulley is using a trivial amount of horsepower (not 3 to 5); you will not be able to tell a difference removing the belt. If the belt is removed there is a very slight chance of brinelling damage to the A/C compressor pulley bearing due to the bearing not being turned over.
Old 11-29-2008, 11:37 AM
RETIRED
Joe Bob's Avatar
You have an A/C in in 80s 911 that works? That's a miracle right there. They sucked when new.
2012 ML350 3.0 Turbo Diesel
Old 11-29-2008, 12:02 PM
Jupiter 911
bklyn's Avatar
Thats half the problem, it works great. I hate to remove something that works, AC here is a must even during the so called winter. But thanks guys.
Old 11-29-2008, 12:16 PM
Make Bruins Great Again
Por_sha911's Avatar
Keep in mind that if you don't run the AC once in a while you will end up with seals drying up (think compressor) and possibly losing R12 if you haven't replaced the stock hoses with barrier hoses. Is 1-2 HP worth it when you have to start replacing stuff?
Joe
Old 11-29-2008, 12:19 PM
Jupiter 911
bklyn's Avatar
No its not and its all been already converted to 134a at my huge expense, your right!
Old 11-29-2008, 12:25 PM
the the is offline
Don't be silly, leave your car alone, run your AC for a few minutes at least once a month to keep it going, don't junk up your car by doing goofy things like taking the AC belt off. The AC should work fine on an 87.
Old 11-29-2008, 12:29 PM
Jupiter 911
bklyn's Avatar
I will have to agree at this point, thanks for all the input, thats how we can keep up on this stuff.
Old 11-29-2008, 12:35 PM
