gjs
glennspiegler's Avatar
Radio Berline Fuse
88 Cab with Radio Berlin Fuse holder below the trunk fuse box. It goes to an amplifier under the passenger seat. Circuit is still hot, but not connected to the radio which is a aftermarket with built in XM. Does this amp have any use or value? There is wire in harness back to the radio for speaker connections which is capped. I've pulled all the wire into the driver side. Could just cut and use the power and ground ends in the driver area as power for Passport 1500 ci. Just having trouble snipping them from a purist standpoint. Thanks, Glenn
Old 11-30-2008, 01:32 PM
