rodoredas's Avatar
What's happened here, is this safe?
I was under the car for a routine inspection and noticed the front stabiliser bar is not evenly positioned in the mounting brackets, looks like it's being forced to one side. I had the front bushes replaced 2 years ago and my mechanic would not have done this. Anyone got some ideas, is this safe to drive? I've got the car on stands and I cannot see anything strange with the stabiliser bar or attachments.
Shane
1975 911 Coupe 2.7L 4Spd CIS Sporto 9115100500
1977 911 Targa, 3.0L, 5 Spd LSD, Zenith Carbs modified, SSI, Dansk 9117310158
Old 12-19-2008, 03:30 AM
"O"man(are we in trouble)
widgeon13's Avatar
Not unsafe but it should be remedied.
Old 12-19-2008, 03:39 AM
MBruns for President
JeremyD's Avatar
Just your front sway bar - and they are a pain to muscle back through. I would see if you can even it back out.
Old 12-19-2008, 06:30 AM
Front sway bar alignment.......
Shane,
Remove the skid plate and loosen the two (2) clamps under the car. Push (use rubber mallet) the end that's protruding until they even up. Then re-align the clamps/brackets accordingly and torque them correctly. Install cover/skid plate and you're done!!!! HTH.
Tony
Old 12-19-2008, 07:53 AM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
LOL! If I had a nickle.
Old 12-19-2008, 09:03 AM
cycling has-been
bkreigsr's Avatar
with the bar in that position, you effectively have a different spring rate in the two front corners.
as mentioned above, loosen, lube, and re-position (big troubles if you manage to pull it all the way out by mistake - be careful)
Bill K
Old 12-19-2008, 10:49 AM
Chuck Moreland's Avatar
I think you are seeing just the tip of the problem.
There is no way that sway bar is in that position, unless the swaybar-to-chassis mounts are bent/missing.
Take off the front suspension lower cover plate and inspect those mounts.
I bet 1AUS dollar that at least one of the mounts are missing.
Chuck Moreland - elephantracing.com - vonnen.com
Old 12-19-2008, 02:01 PM
rodoredas's Avatar
thanks everyone, will check it out today
cheers
Shane
Old 12-19-2008, 02:44 PM
x2 ^ On an unrelated note. I see lime green paint. Got any pics of your car? Theres somthing about that color on a 911 that gets me going
Old 12-19-2008, 06:15 PM
rodoredas's Avatar
porsche930dude, there is some pix here http://users.bigpond.net.au/rodoreda/porsche.htm
it's code 249, emerald green metallic in redbook viper green diamond in the workshop manuals
cheers
Shane
Old 12-20-2008, 08:24 PM
UnRegistered User
billybek's Avatar
Is it possible that your mechanic used the wrong size mounts for the s bar?
When I did mine last spring, the two different mounts looked identical, mine was a couple of mm smaller. I wonder if that is why it is walking....
Bill K.
Old 12-21-2008, 05:11 AM
cheers
awesome thanks
Old 12-21-2008, 08:15 AM
