Just add lightness...
prebordao's Avatar
915 Gearbox oil capacity
Can anyone tell me what is the oil capacity for a 915 gearbox ?
pjr
74' Lime Green 911S Targa
nineelevenophilia.wordpress.com
Old 12-05-2008, 03:57 AM
kodioneill's Avatar
3.0 liter or 3.17 quarts
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-05-2008, 04:11 AM
prebordao's Avatar
Thanks. So a 4 liter Swepco "bottle" will do.
pjr
Old 12-05-2008, 04:21 AM
Yes the Swepco jug Pelican sells is more than enough. Just keep pumping it in there until it starts spilling out.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 12-05-2008, 04:42 AM
MBAtarga's Avatar
Make sure you can remove the fill plug BEFORE you remove the drain plug.
Mark
'83 SC Targa - since 5/5/2001
Old 12-05-2008, 06:10 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
And make sure to fill the trans when is it is nearly level. If you fill it with only the rear jacked up, you will overfill it if you just fill it until it spills out the filler hole.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 12-05-2008, 08:55 AM
What the ?
glewis80SC's Avatar
+1, i learned this the hard way!!!! One Swepco jugs works perfect.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 12-05-2008, 09:21 AM
Since this thread is listed at the top of google results for "915 transmission capacity", I figured I'd bump it to ask a question.
Changed the fluid in my 915 transmission with limited slip differential today.
Upon removing the fill plug, a good amount of fluid came out. I would say at least a quarter of a liter.
Drained, refilled, and was able to put just shy of 3 quarts back in. There was a "good trickle" of fresh fluid coming out of the fill when I put the plug back in.
The car was as level as possible on jack stands. I even measured from 12 o'clock on each wheel opening to the ground; all within a half inch.
Was the transmission simply a bit overfilled?
Old 10-13-2019, 03:25 PM
911 enthusiast
tmadden2's Avatar
A quarter of a liter isn't much to drip out. My understanding is that you really can't "overfill" these systems. Even if you angled the car to fill it in such a way that you got more in than the three liter capacity, any extra just sloshes around without doing any damage.
Old 10-13-2019, 03:32 PM
tmadden2, thanks for the reply.
I filled it until there was a good trickle of fluid coming out, so I don't think I under filled. This is my first 911 so there are plenty of new and interesting experiences. I've never had fluid come out the fill plug of a conventional rear axle differential.
Old 10-14-2019, 06:22 AM
Racer
winders's Avatar
I run "extra" oil in my race car 915...darn near the full 4 quarts with zero issues.
Scott Winders
PCA GT-3R #3
Old 10-14-2019, 01:49 PM
