nh911's Avatar
vacuum line location
Geez one thing leads to another. While working on my csv issue I find a vacuum line that comes from the front of the car into the engine bay. Curious what it goes to up front and where in the engine compartment it attaches. If I pull the air box will I be able to see all the outputs on the manifold?? Maybe I will see the location?
Any vacuum diagrams, cuz I did not see any while searching??
Old 12-07-2008, 04:23 PM
State the model/year you're asking about?
My guess would be that this is a 77-up car with a boosted brake system and the vacuum line goes to the brake booster in the trunk at one end and somewhere under the throttle plate at the other.
'77 S with '78 930 power and a few other things.
Old 12-07-2008, 04:39 PM
Designer King
Paulporsche's Avatar
The Tech Info Center on this site has Parts Diagrams that show vacuum lines for various models.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-07-2008, 05:35 PM
mca mca is offline
mca's Avatar
Could be the atmosphere line to the cruise control servo.
Can you post a picture?
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-07-2008, 06:31 PM
nh911's Avatar
Sorry 1983SC
Thanks so much for the pictures. Nothing like being able to see what the firewall side of things look like. Truly appreciate that!!!!!
Old 12-07-2008, 07:35 PM
