-   -   To remove A/C or not? (http://forums.pelicanparts.com/porsche-911-technical-forum/444928-remove-c-not.html)
teamfee3 12-06-2008 10:28 AM
I'm new to the forum and have an '86 Carrera Coupe with factory AC that does not currently function and that I would not use if it did. Beyond the obvious benefits of removal (weight, power, simplier) would it hurt resale value if it had non-functioning AC on the car vs. removed in a box. It's a clean 78K car that I am going to use everyday for a while and eventually buy another everyday car. I will periodically Auto-X and track it.
Resale matters because I really wanted, and will end up with, an '87-89 or long nose car, or likely a conversion project, but this one was too nice to pass up.
http://forums.pelicanparts.com/uploa...1228587860.jpg
http://forums.pelicanparts.com/uploa...1228588045.jpg
ossiblue 12-06-2008 10:38 AM
My opinion only. Since you are indeed going to sell the car in the (apparently) near future, I'd keep the AC installed. The weight will affect your track times (I presume) but the hp drag will not because the clutch is not engaging the compressor. If you want to be safe, just remove the belt to the compressor. To reach a happy compromise, you may wish to just remove the compressor and evaporator from the engine compartment--save weight and they are easy to reinstall before you decide to sell.
I think having a factory AC helps in resale, even if it doesn't work. Keep as many doors open to potential buyers as possible and fixing an AC is much cheaper and easier than reinstalling the components.
BTW, your car looks truly great. I can see why you just couldn't pass it up.
Zef 12-06-2008 12:04 PM
+ 1...if you plan to sell the car...keep it installed.
the 12-06-2008 12:06 PM
Removed in a box AC = no AC at all for resale purposes.
GBG1000 12-06-2008 12:23 PM
+1
Wow- nice looking car!
porschenut 12-06-2008 12:25 PM
It depends on why it's not functioning. If it can be fixed just by replacing a component such as the compressor or clutch, then it's obviously worth more on the car than in a box.
The key is how much money it's going to cost the next owner to get the A/C working. If it costs more to reinstall the parts, leave it in the car. If it will cost the same or more to get it working (e.g., replacing all the hoses is a lot of labor), then it shouldn't make much difference. I say leave it in the car just to be safe. The next owner will prefer it that way.
A big deal is made on these boards about reducing weight. Will knocking 1 second off of your lap time be worth the hassle and probable loss of resale value? My advice is just have fun on the track and forget about lap times. 60 lbs. isn't going to make any difference in how the car feels. If you want to save 60 lbs., remove 7 gallons of gas from your tank.
the 12-06-2008 12:35 PM
Actually, it's how much money the next potential owner thinks it is going to cost to get the AC working.
That's why the ads always say "Just needs a freon charge!"
kodioneill 12-06-2008 12:40 PM
black car no ac = hot car
carlosR 12-06-2008 01:07 PM
Your car is a beauty. I'm thinking about the same thing for my 77 911S but I think I will remove the compressor so I have more room in the engine bay. If/when I sell this car it's in the box in the trunk if they want it.
canamfan 12-06-2008 01:11 PM
Ohhhh, keep that sweet car looking they way it does, real sweet, don't remove the "working a/c"!!!! my opinon, if I was shopping around for a 911 like that one, I would pay extra for "working a/c", just my opinion
MOMO3.2 12-06-2008 01:17 PM
Yes, very nice looking Carrera. I would DEFINITELY keep the A/C in there.
Mike
Hesse James 12-06-2008 01:52 PM
Nice car! Don't forget to list here when you want to sell
:D
best regards
Heiko
Wickd89 12-06-2008 02:05 PM
Nothing like a black Carrera. Great looking car.
++1 on keeping compressor in a box, and leave everything else in place.
Noel 12-06-2008 07:00 PM
The current economic conditions will have more of a negative impact on the resale than removing the A/C, in my opinion.
the 12-06-2008 07:03 PM
So, I guess the conclusion is keep the AC, but remove the current economic conditions.
spence88mph 12-06-2008 07:15 PM
hehehe, what a gorgeous car! I just removed my compressor and the mount for it which was foolish as it leaves a big hole in the engine tin and will be a ***** to get back on. My vote, remove the compressor (not it's mount) and lid condenser, will save you a fair wack of weight, the compressor is very heavy.
911st 12-06-2008 08:41 PM
It would only save you about 45 lbs.
86 is a great car. It has uprated rear springs and biger ft and rr sway bars. The seat is lowered for more head room. And, it weighs 100lbs less than a 87-89 G50.
Keep the 915 car. Take the spare, jack, compressor out of the trunk and fit a light weight battery for 100 lb savings.
Slip a cat bypass or pre muffler in it, sport muffler, and SW chip for a 2700 v 2900 lb car and about 230-250hp.
If you are going to turbo a car, get a G50.
Noel 12-07-2008 04:39 AM
Excellent point on the weight. There is less weight to a 84-89 A/C system than with the SCs systems. I weighed all components from my system at it was about 80lbs.
KFC911 12-07-2008 05:04 AM
Hmmm...my AC is in a box, and the economy is in a coffin. Coincidence, or should I immediately reinstall my AC as my patriotic duty to help the country recover?
KFC911 12-07-2008 05:10 AM
Resale matters because I really wanted, and will end up with, an '87-89 or long nose car, or likely a conversion project, but this one was too nice to pass up...
Given you've already purchased a NICE Carrera, I personally would not even consider selling it for the purposes of acquiring a G50. If you do intend to sell it however, keep the AC. I removed mine completely from a pristine example, but resale is not part of the equation that I was concerned with. Welcome, and nice car!
alniki 12-07-2008 05:30 AM
Nice car!
I just removed the compressor from my '87. Yes, it's not a lot of weight but it's hung pretty rearward and the removal makes the engine compartment look better and more focused. Reinstall is easy and I think can be done in less than 30 minutes if you are selling the car someday
teamfee3 12-07-2008 08:26 AM
This forum is incredible, I hope I can make a decent contribution one day. I am going to keep the A/C in, remove the compressor but leave the mount. It looses some weight, cleans up the engine bay and looks like a clean job in and out. If the A/C could be put back in action easily I might do that but I would never use it and life tells me if something isn't used it generally stops working at some ppoint anyway.
I also like some of the other suggestions. I'll post a before after once the motor is back in - also deciding on engine fan, currently gloss black housing with silver fan but might change it.
This is it as I bought - more to come....
http://forums.pelicanparts.com/uploa...1228667146.jpg
NO LIFT 12-07-2008 08:54 AM
I'm in the same predicament. A/C I that doesn't work, and I haven't fixed it anyway. Thanks for the great advice from all.
But, what do I do with the open hose ends after I remove my compressor and evap from the engine compartment?
Guidance would be appreciated!
KFC911 12-07-2008 11:01 AM
This is what I did a few years back:
http://forums.pelicanparts.com/porsche-911-technical-forum/231053-gratuitous-pics-carrera-heater-backdate.html?highlight=gratuitous
alniki 12-07-2008 05:27 PM
I took some PE wrap from the kitchen to wrap the the open hose end and just displace the hose to under the oil filter.
I didn't remove the evap because my turbo tail was off and I need the evap to work as grill for now :D Any one has a spare engine lid grill for sale?:)
GH85Carrera 12-07-2008 06:52 PM
So your are the culprit :D
Dang man, put that A/C back in and go buy bunch of stock! We are all counting on YOU.
