450knotOffice's Avatar
Question Nitto NT-01 tire pressures?
What pressures do you guys run with these tires at the track? First time user and I need a starting point. Thanks guys.
Old 12-08-2008, 03:52 PM
Diss Member
Quicksilver's Avatar
Hey Scott, what size of tires/wheels and which car?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-08-2008, 03:57 PM
Jeff Alton's Avatar
i found good grip in them at 35F and 37R (hot) 225/255. With my car and set up this gave me even temp across the tread.
Cheers
www.turn3autosport.com
Thanks Jeff.
Wayne, they're on the '84 Carrera, which weighs about 2550 without me in it but with a full tank of gas. 225 Fronts/255 Rears.
Old 12-08-2008, 04:02 PM
Jeff, what cold pressure will get me near that 35/37 hot number?
Old 12-08-2008, 04:04 PM
Jeff Alton's Avatar
It all depended on ambient temp.
I have started any where from 27/30 to 32/34. Once in the 35/37 range they seemed to stay there. The temp was taken after a cool down lap and I got out and measured them as quickly as i could, same goes for the temp readings. I was seeing around 175-180 across the entire width of the tire.
Mind you my car weighs 2250lbs.
Cheers
Old 12-08-2008, 04:24 PM
Thanks Jeff.
Old 12-08-2008, 06:32 PM
I also run my rear NT01's at 37 hot (32 cold) different size though 245/50-16 (9" fuchs)
carrue529
1987 911 Carrera
S.Wong chip|ElginCams|GT3 oil pump|short gearing|Guard TB-Diff|22/29 Hollow T-Bars|monobloc calipers|Bilstein HD/Sport|Turbo tie rods|Strut brace|CobraMonza II seats|7, 9 Fuchs|Elephant polybronze bearings F/R|Wevo eng mounts|bypass cat pipe|M&K muffler
Old 12-08-2008, 07:02 PM
