Super Moderator
cstreit's Avatar
Reference: 1970 wiring harness weight
For future reference. Just pulled out the original 1970 wiring harness from the racecar in anticipation of a more efficient setup that isn't 40 years old...
Total weight including the fuse panel and battery wiring? Right around 15 lbs.
That is all.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-07-2008, 08:58 PM
AutoBahned
RWebb's Avatar
your information has been assimilated
- Das Borg
PS - wiring on a 928 weighs about 35 lbs. That was in an article in Excellence -- the same issue that had the article on Jim Calzia's lightwt. 911.
Old 12-07-2008, 09:30 PM
Super Moderator
cstreit's Avatar
I wish I had weighed all that stuff I pulled out too for reference. I just thought the harness was pretty uncommon and worth weighing. This should put my weight right around 2050# with the 3.0L and 915. I think the G50 update will probably add 40-50#.
I really wish there was a less expensive way than moving the oil-tank to shift some weight forward.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-08-2008, 06:05 AM
AutoBahned
RWebb's Avatar
so do I!
is there any component you need a wt. value for?
Old 12-08-2008, 10:20 AM
Super Moderator
cstreit's Avatar
Thanks, but I'm so far beyond and reasonable calculation, right now the car is a shell with suspension.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-08-2008, 11:20 AM
