-   -   Help! (Frequency Valve on SC)? (http://forums.pelicanparts.com/porsche-911-technical-forum/4454-help-frequency-valve-sc.html)
CEO 05-31-2001 03:18 PM
Here is the story. I just put my motor back in my 81 911 SC after detailing it(It looks great). And having the car repainted. The car only sat up for 8 months and ran beautiful before the motor was out. Now with the motor in it ran like crap when cold and not so good warm either, so I took it to my Automotive tech. friend, after testing the car he is telling me the frequency valve is bad. Where is it and what does it look like? He is telling me that the motor has to be dropped to put in the new frequency valve. AHHHH $1200 later. Any advice would be great.
Kenneth
Silver 81' Targa
john walker's workshop 05-31-2001 03:32 PM
make sure the relay that operates the lamda system is ok. if the lamda computer is not turned on, the frequency valve will not work. the relay and computer are under the passenger seat. the relay gets it's power from the domelight fuse. $1200? new tech time. ripoff!
[This message has been edited by john walker's workshop (edited 05-31-2001).]
CEO 05-31-2001 03:49 PM
I was under the impression that the SC's did not have computers. Everything was mechanical. And the box under pass. seat was the the curise control unit. Am I wrong?
Kenneth
Silver 81' Targa
wckrause 05-31-2001 03:52 PM
80-83 US SC's had the K-lambda system with the lambda controller under the passenger seat, and an 02 sensor. Earlier SC's and ROW SC's had the K-basic system without the 02 sensor.
gslater 05-31-2001 03:54 PM
The box under the passenger seat is the computer for the K-Jetronic w/ Lambda fuel injection. Just on the '80 - 83 SCs (which have oxygen sensors), I believe.
Greg Slater
1980 SC
gslater@qwest.net
gslater 05-31-2001 03:55 PM
Whoa! Those were eerily similar replies that we apparently wrote simultaneously...
Greg Slater
1980 SC
gslater@qwest.net
Jim Smolka 05-31-2001 03:57 PM
On the Freq valve, there is a multi pin connection in the motor compartment. Maker sure that it is not lose. Also, with the ignition on and the engine off, you should here a humming sound in the back center of the motor btwn the 2 rear shocks.
Also, I think you can lower the motor enough so that you can replace the valve but still have most things connected.
wckrause 05-31-2001 03:58 PM
I beat you by two minutes.
BTW,
real Porsches don't have computers!!!
Bill Krause
'79 911SC Euro
