-   -   How far beyond 7K have you been?? (http://forums.pelicanparts.com/porsche-911-technical-forum/445567-how-far-beyond-7k-have-you-been.html)
Porsche_monkey 12-10-2008 06:59 AM
Originally Posted by dfink (Post 4351247)
I'm guessing at somewhere around 11K to 12K.....
Once............
Me too. Stuck throttle. pushed the clutch before I turned the key.:rolleyes:
1982911SCTarga 12-10-2008 07:24 AM
Bill Verburg posted this information in the past:
oem limiter specs
930/03 & 13 6800+/-200
930/04 & 05 & 15 & 06 6700+300
930/07 & 08 & 16 & 17 6500+200
Robert, if your cabriolet has its stock 930/16 engine, your rev limiter (the black box under the far left of the dash) should have cut off the fuel pump at 6,500-6,700 RPM.
Brian (who has never approached a rev limiter cutoff) ;)
cstreit 12-10-2008 07:27 AM
I ran my stock 3.0L up to about 7800 RPM once.
http://www.seinesystems.com/Images/CStreitBentValve.jpg
http://www.seinesystems.com/Images/C...ValveGuide.jpg
Now it's built to 8.2k and I run it to 7200.
1982911SCTarga 12-10-2008 07:32 AM
That one valve does look a little out of skew. ;)
Brian
LeeH 12-10-2008 07:37 AM
9K or so on a missed shift. I won't post the pick of the six bent exhaust valves... very similar to the pic above, but thankfully no other damage.
AZ1977911 12-10-2008 07:49 AM
About 3 times (or did you mean RPMs instead of Dollars)...
LeeH 12-10-2008 12:44 PM
Originally Posted by cstreit (Post 4351928)
What exactly am I looking at in this photo?
cgarr 12-10-2008 12:46 PM
Looks like a bent exhaust valve that took out the guide. Those are really bent or my astigmatism is really bad!
dickepoohp 12-10-2008 02:44 PM
Back when dinosaurs trod the earth, I was able to talk a buddy into swapping P-cars for the drive from Mobile to Talledega. He "got" to sheppard my '57 1600 normal speedster, and I was forced to drive his '56ish 1500 Carrera with four cams, two mags, dual spark plugs (absolutely unreachable)no sound deadening, plastic windows with leather straps for regulators.
Redline as I recall was just over 8,000, something I never reached due to the NOISE, the aggravating part was the GREEN line of 4,000. Drive under 4 for ANY time, and you found yourself on the side of the road, employing a cable ratchet extension device to attempt to pull all 8 plugs. In first, the Tunnel traffic was moving at less than 3,000. He was screaming "Blip it!!!" As I coasted to a stop at the bottom of Bankhead tunnel.
I wonder if it would seem as torrid today...seems like the Speedster had 60hp and the Carrera 120...about half what a really healthy VW will do.
pwd72s 12-10-2008 05:44 PM
Factory redline on an early S is 7300...
Mycar 12-10-2008 10:15 PM
It is indeed and I`ve been up to the limiter a few times...... but looking at these photos, perhaps not so often from now on :)
Mike.
petevb 12-10-2008 10:36 PM
The redline on a GT3 is 8400...
