Yes, I will definitely be reading Jeff's thread on his rebuild.
I love ITB's. I'd love to build a 3.2SS with PMO ITB's, twin plug, TEC-3, and S cams. If I can do that without busting my budget (including professional tuning), I wouldn't hesitate. Could an engine like that pass an emissions test? |
Call Orin @ 303.789.2545. He is great at getting hotrod engines through emissions.
Way too many options! Is mechanical fuel injection particularly expensive or challenging to implement? Should I even consider it? |
Get Bill V to comment on gear ratio's....and brakes.
MFI is tough because it runs off a pump that is driven by a belt attached to one of the cam shafts. Obviously the non MFI motors do not have the attachment on the cam shaft. It can be added...its only money. There used to be a guy on here who had a 3.0 with MFI. I think he sold the car..very dreamy.
Also, I think the modern FI is such a huge step up in tuneability and ease of operation you would be better going after the "look" with some tall trumpets but actually using sensors and computers to fire the fuel instead of cam driven. |
careful on the 7:31 . the torque and use/ abuse ? will wear it out quickly. Better bet to keep the 8:31, wevo or similar billet side plate, and go with shorter gear sets.
we have had several clients (inc myself) bust or wear out 7:31's in high torque/ hp cars db |
I posted this on another thread but hope this will help. 3.2 in my SC. I can tell you the driveability, usable torque, etc. is great.
http://forums.pelicanparts.com/uploa...1229032544.jpg http://forums.pelicanparts.com/uploa...1229032555.jpg 1986 Euro Carrera motor rebuilt by Chris Powell of Chris' Foreign Auto in Bellevue, WA. Dyno tested at 210 SAE HP at the rear wheels. Adjusting for drivetrain losses and converting to DIN gives 255 HP at the crank. Rebuild details: 10.3:1 compression ratio Euro pistons and cylinders; low mileage 964 turbo crankshaft; 993 cams; cylinder heads ported and polished by Chris; case webs relieved for windage; ARP rod bolts; rods rebushed, balanced and resized end-for-end; pistons weight balanced; crank, flywheel and pressure plate balanced; throttle body bored out 3mm; intake manifold “ported” for larger throttle body and polished; injectors rebuilt and blueprinted; adjustable rising rate fuel pressure regulator; SSI headers with fully functional heat exchangers; new CV joints and axle shafts; Monty dual outlet muffler; Autothority chip customized for application. Some would probably argue the calculation on the HP conversion. I don't know enough about it to comment. This motor came with the car. If the criteria is to build your motor yourself, I would think this could be the way to go. |
buy the car on ebay and sell your car . that is a bargain!
My favorite is the 3.2L to 3.5L conversion carrera3.5L documented some time ago. California street car with 246 whp and 224 lb-ft of torque.
http://forums.pelicanparts.com/porsche-911-technical-forum/186906-3-2-3-5-part-ii-8.html |
Too bad you guys aren't located closer to me. It would be great to have TRE involved in the project. |
Dude, I would be all over this... http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/445936-964-3-6-engine-sale.html
If, when, I do it again, I am going for more displacement. I am still toying with the 3.7 idea this winter but time is an issue for me.
From scratch, I would build a 3.9 or 4.0 with ITB's....... Cheers |
I would like to have Todd at Protomotive convert the Motronics to a vac sensing system that would work with a set of Individual Throttle Bodies. Set it up with PMO units and get a set of early air cleaner tin to make it look stock.
Get a twin plug retro distributor and an Andial signal splitter. Maybe some and amber motor shroud. Could bore the cylinder, have them plated, and use J&E's unless some 3.4 or 3.5 MFI or Carb P&C's could be sourced. I'd also spend some of the money on the trans for some short gears. :D |
This one gets my vote: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/445156-3-6l-race-motor-350hp-turn-key.html
And after you buy it you'd even have some $$$$ left to play with... |
Ask TRE about the RS clone motor they are building. It's probably a bit short on HP, but authentic for an RSR type toy.
| All times are GMT -8. The time now is 08:44 AM. |
