Here's a very close estimate. If you stay with Motronic (single-throttle body) and avoid things like Titanium valve spring retainers, you can save $1500 or so off this estimate.
You could also probably spend just about the same money for rebuilding a core 993 engine, after selling your 3.2. That might be a better choice, certainly a better hp/$ ratio. But this is from experience: http://forums.pelicanparts.com/uploa...1229062896.jpg [this isn't a plug to sell a rebuild--I'm busy enough] |
I just got done reading Trog's PMO ITB thread, and I was blown away. After that, I can't imagine not doing ITBs. Displacement and piston/cam selection seem to be the big remaining questions at this point. BTW, I appreciate all the suggestions. It's definitely helped me to figure out what I want. Now if I can just figure out what that is.... |
It is a sweet motor, and a good deal, IMHO. Can you hold your horses, and drive it conservatively...cough...:D? Dude, stop redlining that thing after every stop light! http://forums.pelicanparts.com/support/smileys/wat3.gif
Numbers look not too bad either...buy that one for 11.5 sell your 3.2 and you left with decent reserves if service is needed...I dunno, just thinking outloud. Quote:
How about just going for short gears and light weight. With a custom chip and free flowing exhaust you could have 250-260 hp. Get the weight down to 2200 lbs and you still have a combo that is tough to beat and smog can be easily handled.
In Calif. a 76 911 is smog exempt. I know of an 84 Carrera Turbo Look with 250k miles that would make a great core for a build. Already has turbo fenders, a LSD transmission, 930 brakes, better 930 rear swing arms, and 7&8 Fuchs for less than $15k. |
1 5/8 to 1 7/5's headers with a good sport/race muffler (Flowmaster, Coast, Magnaflow) set up should get you there with a custom chip from 911Chips.com. If you are willing to run race gas it is possible to get up to 270fwhp with the right exaust and stock cams.
I am not an expert but I would not spend money on a cam change on a 3.2. With that you should have the rockers redone & sport valve springs. If I was opening it up to a 3.4 or more that is different. A friend & I are seeing 210-220rwhp with a bypass & chip. That is 250+ fwhp. I do not think the intake side is much of an issue. Check out the dyno charts at 911chips.com. Just keep it away from 7k as the rod bolts are a potental issue. |
