zugelassener benutzer
Bursch cat bypass on 86 3.2
(I did search and didn't find anything.)
Anyone installed the Bursch cat bypass with O2 sensor? Pros / Cons? I run a stock motor with a B&B twin outlet exhaust and a chip of unknown origin. I'll run the car everyday and don't mind a little noise but not looking to draw Police attention. Want to keep my heat so this cat bypass pipe and the B&B seem like a great compromise. What kind of hp / torque add should I expect? Noticeable? I assume less weight, more power, and louder. I am also assuming an '86 with historic tags is emissions exempt?
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
THE IRONMAN
I have a Bursch catbypass installed on my 84 3.2 along with a Monty Free Flow 100 mm. The chip installed is a SW one (the best one) I like the refined throaty sound, not too loud, just enough. IMO you'll get no HP gain by replace the cat exept if the cat is glogged.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> Last edited by Zef; 12-13-2008 at 11:46 AM.. |
I like mine, adds a little bit of sound, but not too loud.
