-   -   74 front valence; how do I get it off? (http://forums.pelicanparts.com/porsche-911-technical-forum/446049-74-front-valence-how-do-i-get-off.html)
moneymanager 12-12-2008 01:53 PM
Did a search, found nothing on this point. I'm trying to pull the front valence (the metal piece under the bumper.) There is a big 13mm bolt on either side, and 2 small screws near the wheel arches. The valence seems to be secured at two other points maybe a foot on either side of the center. It looks like there might be a screw from inside the trunk into something, but if there is I can't find it. I'm praying I don't have to pull the bumper to get at this. Anyone done it?
Liam O 12-12-2008 02:49 PM
Yes, there are two screws exactly as whhere you describe them .You can get at them from inside the luggage compartment,take out the spare,jack,tool kit etc stick your head in there and you should easily find them.
moneymanager 12-12-2008 03:38 PM
Great. I see them. I guess I wasn't looking close enough to the outer edges on my first pass. Thanks much; the valence is now out.
