-   -   My first engine build complete - the 3.2SS is alive. (http://forums.pelicanparts.com/porsche-911-technical-forum/447355-my-first-engine-build-complete-3-2ss-alive.html)
jpnovak 12-20-2008 11:13 AM
I know many of you don't read the engine building board. Most of you do a lot of DIY projects but might think that engine internals are some kind of black magic. Let me just say that there is a wealth of information and if you are detail oriented and mechanically inclined you too can build your next 911 engine.
I rebuilt the top-end due to head stud failure. I am not going to recount the whole build here. The following link will show previous posts on the build.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/435994-3-2ss-continues-part-iii-assembly.html
If you are just starting the engine specs are as follows.
1978 930/03 base engine
98mm Mahle PC set.
Measured 10:1 compression
DC 40-108 deg cams
steel head studs
Home-made twinplug distributor using Jaguar 12-plug cap and Burn-Bros. rotor. Thanks Aaron!
Twin-plug heads by G2 Racing. Thanks Craig!
Ceramic Thermal barrier coatings on heads and piston crowns
Dry-film lube on cams, rockers, rocker shafts, piston skirts, wrist-pins and every other moving part I could find.
TWM 3003 ITBs
MegaSquirt ECU (MSII-V2.2)
A few weeks ago I was able to get the motor back in the car. Last week I finished wiring up the motor only to find that my Crane optical trigger was not working. Late Thursday night I sorted it out. (Read: A new one was delivered by FedEx Ground).
So I connect the ECU, disable the motor, pull the top plugs and spin the motor with the starter. I was getting about 1.2-1.3bar of pressure off the starter. Enabled the engine by connecting the ECU and installing the plugs.
I was not expecting the motor to start right away. The motor took half-a-turn and fired to life. I was a little freaked out and shut it down quickly. I am not sure why. 10 seconds later I fired it up again. Once it was running I stabilized the map and it was loping along at 2100 rpm to break in the cam. It was running a too rich to explain the loping. After my 25 min cam break-in I made some more changes to the EFI map.
Here is the result:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/6SqYOT5AXRs&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/6SqYOT5AXRs&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
now I need to reset the AFR at idle, balance the throttle shafts and lean out the acceleration enrichment.
I am so stoked right now. I don't know if the high is from the unburned fuel vapors or natural euphoria.
Not a drop of oil anywhere that I can find.
ianc 12-20-2008 11:45 AM
Great news Jamie!
I love that moment when you first twist the key and it fires right up!
ianc
Jack Olsen 12-20-2008 02:02 PM
http://www.wrtc.com/dcmaurer/frankenstein.jpg
Mark Wilson 12-20-2008 04:20 PM
Congratulations - great to hear the beast come to life.
Zeke 12-20-2008 04:31 PM
Excellent! You are the spirit of the forum with all your projects.
Jim Richards 12-20-2008 04:43 PM
Congrats Jamie, you crazy mad scientist! So, now what are you gonna build in your top secret laboratory?
juicersr 12-20-2008 04:52 PM
Jamie, http://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/clap.gif
Good job. Great early Christmas present eh? I bet you crack 250bhp when you get around to dynoing:)
Would love to hear your subjective driving impressions of the motor (torque, revability, etc) compared to prior stock motor.
4flyboy 12-20-2008 04:56 PM
You have a bigger set than I do!!
Someday when I grow up. Congratulations..
Scott
richemj 12-20-2008 07:01 PM
Awesome build Jamie! Looking forward to seeing it up close during the Rally in April.
Jeff Alton 12-20-2008 09:12 PM
Nice job! Now get some agressive miles on it quickly to seat the rings!
Cheers
jpnovak 12-21-2008 05:24 AM
Jack and Jim, I resemble that picture and remark. )
My goal was 260 at the crank. I think I might exceed that a bit. It will depend on how much torque I am still making at higher rpm. I mostly wanted higher rpm power like my targa.
Rich, Are you going to make it up for the rally? I thought you were doing the MS150.
Jeff, Don't worry, there will be some quality time that connects the go-pedal with my right foot. I have to remap the EFI with the new displacement and cam profile. This shouldn't take too long but there will be a lot of pulls down my "secret" tuning streets.
sjf911 12-21-2008 08:17 AM
Welcome to the 3.2SS club! Congratulations on the build. I have only one question. Having grown up in Austin, I know what Austin summers are like (all 9 months of it) how are you going to live without A/C?;)
jpnovak 12-21-2008 01:36 PM
I have not had AC in the 911 since it was built. I just don't drive it much between June and September. The other months are fine.
Bertstoy 12-22-2008 07:38 AM
Hi Jamie.... Great job. Your car sounds fantastic for the fist run. Good luck and I hope to get mine running soon. Thanks again for all your help on the M/S
steve
