irl irl is offline
irl's Avatar
Send a message via AIM to irl
new plugs and magnecors, car died?????
Installed new plugs and magnecore wires on 71T, car test drove and then while idling in garage when I got back, it just died and wont start. Any help???? And its not the little wire on the cap
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-21-2008, 01:19 PM
sudo apt-get purge 930
equality72521's Avatar
Make sure the coil wire didn't back out. I used Magnecors and I had no end of trouble with the boots slipping.
--clutch-monkey
Old 12-21-2008, 01:28 PM
irl irl is offline
irl's Avatar
Yea I did, also put original coil wire back in just to test it. Milt gave me a checklist when I had problems before, I need to check that Im getting that spark to the wire. Just wanted to see if someone knew something about new wires causing another problem. I have all new parts for the dist but I dont wanted to noarrow the cause down first before I go there.
thanks
79 SC unmolested
25 GTS
Old 12-21-2008, 01:44 PM
irl irl is offline
irl's Avatar
Need help, engine cranks, see no spark on plug ends, now what???
79 SC unmolested
25 GTS
Old 12-21-2008, 05:43 PM
haycait911's Avatar
back to basics, is there spark at the coil wire while cranking? if so, maybe put the old wires back in to eliminate the new wires as the problem. I've had many instances where things that seemed related weren't, just a coincidence.
maybe you bumped/moved something during installation ( like a distributor cap ) and it was loose enough to subsequently disconnect itself? most times my car has done this kind of thing it was something I did without realizing I did it. ( if that makes any sense ) .
Old 12-22-2008, 01:45 AM
Your CDI could have been toasted or the coil may have failed.
Borrow and try to replace.
John
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 12-22-2008, 03:09 AM
