-   -   Spark Plug rec's for 67 Normale? (http://forums.pelicanparts.com/porsche-911-technical-forum/447671-spark-plug-recs-67-normale.html)
tadink 12-22-2008 03:37 PM
Please forgive me, I've searched, and trolled the postings but I cannot find a definative answer on what are the appropriate spark plugs for my 67 911? The car is used on the streets and up mountain roads, no track time. Many thanks in advance....interested in options and availability. Pelican sez OEM Bosch plugs NLA.
Tom
SF
1967 911 Normale
tadink 12-23-2008 02:42 PM
answer to my own post
Hey all....
got this answer to my post on the early 911s registry - - here is what they say, I'm assuming it to be correct....
"NGK B6 or 7. The lower number is a hotter plug, run the hotter plug if in a cooler climate and moderate RPM. I run 6's or 7's in my carbureted 2.7, both perform great, inexpensive and available at your local parts joint."
just in case anyone else is searching for this same info....
td
