window closes too high
I sure this has come up in this forum, but I have search and have not found anything.
The window on my cab closes too high http://forums.pelicanparts.com/uploa...1230240219.jpg I saw some post on the window regulator, but they did not seem to mention this specific issue |
Remove door trim adjustment bolts will be visible
Although I haven't tried it yet, the Bentley service manual has a couple of pages on this as it seems to plague the cab and targa guys. My guess is that previous owners take the car in because it either leaks, makes noise, or both and in order to fix those issues, the resolution is to have the windows go up too far. On my targa, they go up so far similar to your photo that the windows protrude at an odd angle when I go to shut the doors! I hope to make this a winter project time permitting.
- Darryl |
The oblong slot shown in GothingNC's post does the adjustment. That happens to me over and over again. I can adjust it so that it works well for a while but with time it slowly creeps higher and higher until it is back to the condition in your picture. I've even considered putting limit switches and relays!
| All times are GMT -8. The time now is 01:11 AM. |
