-   -   I need help with anodized Fuchs (http://forums.pelicanparts.com/porsche-911-technical-forum/448185-i-need-help-anodized-fuchs.html)
mnmasotto 12-26-2008 10:07 PM
I have baked on water spots on the anodized portions of my Fuchs. I cannot seem to remove the spots with soap and water. I do not want to damage the anodized coating? Any ideas on what to use.
Thanks in advance, Mark
the 12-26-2008 10:19 PM
There is no permanent repair you can do to the damaged anodized surface, but you can rub the anodize down with Vaseline and you can probably hide most of it.
Tsunamiboy 12-26-2008 10:28 PM
If it is mineral deposits from hard water try water & vinegar.
porschenut 12-27-2008 06:59 AM
Mark, petroleum jelly works wonders and removes the water spots beautifully. Just rub a light coating on and then wipe it down with a dry, soft cloth. The owner's manual recommends regularly using petroleum jelly to treat Fuchs wheels.
911s55 12-27-2008 07:14 AM
Here's another product I use.
http://www.roadsters.com/gibbs/
jorian 12-27-2008 11:23 AM
Vaseline works OK on the anodized part (OK from 10 feet). Vaseline works GREAT restoring a little depth to flat black paint that is discoloured.
JackMan 12-27-2008 04:15 PM
A little PS21 polishing compound will work great. It is available from our host. I use vaseline as well. If it's cold outside, I find that it helps to warm up the wheels. I do this by removing the tire and wheel and putting both in a cardboard box into which I have cut a hole to put in a hairdryer. Leave it for a few minutes and the wheel warms up. I guess this opens the pours of the metal and makes it easier for the vaseline or PS21 compound to work into the metal.
wj
mca 12-28-2008 01:07 PM
If it isn't water spots it may be that some degreaser got on the wheels. I did this the first month I got my car. While cleaning up the tires some of the degreaser ran down along the anodized rim and ate up the finish. Unfortunately it can't be fixed.
