-   -   Found some bits in sump screen of my 72 T (http://forums.pelicanparts.com/porsche-911-technical-forum/448354-found-some-bits-sump-screen-my-72-t.html)
doros911 12-28-2008 09:45 AM
Hi all, I'm having a problem here, I removed the sump screen and I found a lot of debris including the two big pieces in the pictures below. It all looks plastic, no metal bits at all. Engine is 2.4 from a 1972 911T. Any ideas what these are? Thanks
Badge for size reference.
http://i139.photobucket.com/albums/q...1/08122807.jpg
http://i139.photobucket.com/albums/q...1/08122811.jpg
http://i139.photobucket.com/albums/q...1/08122812.jpg
http://i139.photobucket.com/albums/q...1/08122814.jpg
http://i139.photobucket.com/albums/q...1/08122818.jpg
4sd911 12-28-2008 09:51 AM
Looks like parts of the chain guides. These can be accessed through the chain covers. When you get a look in there check your tensioner's. Oil will need to be dumped at lest out of the engine case.
Zeke 12-28-2008 10:40 AM
I'm pretty sure he's right about the chain ramps. Might be time for a Carrera tensioner upgrade.
aigel 12-28-2008 11:01 AM
Chain ramps. There are not a lot of plastic parts in the flat six. I would investigate (take chain covers off).
George
JeremyD 12-28-2008 11:33 AM
What the others have said - take the engine sheet metal off the front and talk the chain covers off. I think you'll find at least one of them in lots of pieces.
doros911 12-28-2008 12:50 PM
Thanks fo the replies guys. PO mentioned he's had some work done on the tensioners, maybe the debris is from that time (I hope). I can't figure out through where these remainings found the way to the screen though.
aigel 12-28-2008 02:21 PM
Gravity will work them down into the case.
George
ks2_motorsports 12-28-2008 02:24 PM
definetly chain rails...looks like the real old original types...
