peters911s's Avatar
What are these?
Can anyone tell me what this cannister is and what the tubes surrounding it are?....This is a 77 911S Type 85 motor...TIA...Peter
1990 BMW 325is
1977 Porsche 911s
1979 Alfa Romeo Spider
1999 Lexus LS400
1978 Porsche 911 SC 258,000 miles and barely run in!
Old 12-29-2008, 04:07 PM
Happiest when Tinkering
gsmith660's Avatar
Air injector tubes and the EGR stuff
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-29-2008, 04:27 PM
peters911s's Avatar
Are they easy to remove?....or better just left alone?....engine runs great right now with 197000 miles.
1990 BMW 325is
1977 Porsche 911s
1999 Lexus LS400
Old 12-29-2008, 04:39 PM
MBAtarga's Avatar
One deciding factor is if the car is subject to emissions testing.
Mark
'83 SC Targa - since 5/5/2001
Old 12-29-2008, 05:27 PM
gsmith660's Avatar
Fairly easy to remove but you have to plug all the holes, +1 on if you have to do emmissions testing leave the stuff alone.
Old 12-29-2008, 06:13 PM
peters911s's Avatar
Car is in WA and is exempt from emissions...If i were to remove...what would you suggest i plug them with?....would someone here be able to make use of?
1990 BMW 325is
1977 Porsche 911s
1999 Lexus LS400
Old 12-29-2008, 06:41 PM
ruf-porsche's Avatar
If the engine is running right, just leave it alone.
Old 12-29-2008, 06:47 PM
zotman72's Avatar
The plugs are available, not sure if you can get them from our host (did not look). Be careful in the removal of the air injectors or you might make screw up the threads and have to tap out to a larger size plug (that happened to me on one hole). I used Blue loctite to seal the plug, I think there is a copper washer on the plug too.
HTH and YMMV.
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 12-29-2008, 07:47 PM
signature65's Avatar
I would say leave it alone.....you will get no power increase with that removed. The only diff is less weight from what you took off. The air injector system injects air in the exhaust cycle to allow the unburnt gasses to have some fresh O2 to combust with in the exhaust. So no power gain to be had. It acts as a pre Catalytic converter.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 12-30-2008, 12:09 AM
CT944's Avatar
I have the 6 plug screws with copper washers. I bought them but never used them. $15.00 shipped. Let me know if you're interested.
2007 997 TT
1992 500e
Old 12-30-2008, 04:51 AM
