Next question - how are you guys mounting, holding or positioning the iPhone during the test? Will a jury-rigged arrangement such as rubber-banding the iPhone to the sunvisor work?
You guys are going to make eveybody want to buy one of these things, including me.
You are correct sir, and this makes the most sense. Why else would it be reading 70MPH from just tilting it in my hand? :)
I did 6 runs and that was plenty. I really don't need to tear my tranny apart right now. If the app is updated with major improvements or I change my car, I'd make a couple more runs.. |
do they have an app for the track? for like lap times and G's thru turns?Not to interested in straight line info..
http://www.tomatounion.com/index.html |
Q: What is the best way to mount the iPhone when testing? A: Mounting is a concern for accurate results. Unfortunately, mounting is very vehicle-dependent. On some cars, a cupholder is fine, as long as the iPhone is wedged pretty well and does not move around. For in-house testing, we have a cradle which mounts to the windshield with suction cups. This took a bit of custom work to set up, but does the job nicely. Any off-the-shelf cradle which fits the iPhone should work, as long as it holds the iPhone facing the front of the car, and does not bounce around. |
anyone know if this works for similar phones? Not iphones?
A: At this time, we are porting Dynolicious to the Blackberry Storm. We currently do not have plans to support any other platform. The best way to convince us to port Dynolicious to something else is to visit our forum and show your support. |
Not a good run
You can see a lot of hesitation during the run, and the fact that I take my time to shift the 915.
I also had 525lbs of human in the car. (My passenger with the iphone weighs at least 300). We also guessed on the weight of the car, with us. http://forums.pelicanparts.com/uploa...1238257466.jpg http://forums.pelicanparts.com/uploa...1238257497.jpg |
If your passenger was holding the i-phone, that would explain the non-smooth curve.
I believe he was.
I am about to get one of these; I am just wondering if the arm is long enough with the dashboard over the lighter plug...
http://www.hdaccessory.com/servlet/the-1055/Apple-iPhone-iPod-Touch/Detail http://www.hdaccessory.com/catalog/fmledblack1.jpg |
I didn't have the best luck with FM transmitters when I was using my iPod in the 911. I ended up using a wired connection.
That said, the device you linked to is inexpensive enough that there's no reason not to try it. |
Sorry what forum? Iam not sure if my Delve would work or not for this but would be interested if so |
http://www.bunsentech.com/forum/viewforum.php?f=4 |
I just installed PocketDyno on my iPhone before realizing that Dynolicious was a different app. Has anybody compared them? I installed the $12.99 version of Pocketdyno. I like the graphics on Dynolicious.
Now all I have to do is find a stretch of road to try it out on. |
| All times are GMT -8. The time now is 12:59 PM. |
