Hola eric |
Bosh Light'em Up Apps
How did you make out with this mount? Is it worth it? I just installed the Bosh Apps (free/$4.95 for the advance) Light 'Em Up | Bosch Invented for life on a Iphone 4. Work great on the Odyssey but I need something steady for Das Babe :D;):D I look at this one or one that Suctioned Cup to the windshield. J.J. |
Those cigarette lighter mounts work OK in an SUV, but particularly if you use them to measure acceleration in a 911, you're going to end up with your iPhone on the floor.
Velcro strap it to the rear view mirror.
I got 2 coming.
I'll use the one with the windshield suction cup for Das Babe the other will be for the Van Check Post 4 of http://forums.pelicanparts.com/porsche-911-technical-forum/560515-light-em-up-app-bosch.html#post5523278 for details of this run... http://forums.pelicanparts.com/uploa...1282667495.jpg |
Your van is pretty damn quick!!
The downs side is...
I gotta get this app.
I'm dying to know what kind of #s my allegedly rebuilt 2,2 t puts out. |
It's a cool toy but of course take it to a dyno to see where it really is, then compare the numbers..
The 911 Buyers Guide posted by our host, lists the 1978 911SC at 2560lbs. I don't know but would guess that is without gas, driver, or anything in the trunk.
There are a bunch of free ones. You don't have to buy the dynolicious one.
First run with Dynolicious/iPad. Slightly uphill, two passengers total weight 3020 lbs. SC cam. It appears to have a wide spread of torque doesn't it ? Not very fast though
Comments please ?http://forums.pelicanparts.com/uploa...1295791461.jpg |
I found that after about 30 runs, I only got two that were close to what I pulled on a dyno. It's kind of tough to find: straight, flat, non-populated and where you can get several runs in, at least in my neck of the woods. To get away from people, I get lots of hills/mtns and twisties. Darn!
OH, and holding it securely is mandatory! |
Dug up this old thread and figured I'd post my results from last January.
First run. Moderate launch. Decent 1-2 gearchange. http://i906.photobucket.com/albums/a...r/firstrun.jpg Second run. Tried a 4k rpm launch and just spun the tires. 0-60 wasn't as good, but had my best 1/4 mile. http://i906.photobucket.com/albums/a.../secondrun.jpg Third run. Moderate launch like run one. http://i906.photobucket.com/albums/a...r/thirdrun.jpg Weight entered in at 2700 lbs. This was just a guess. This is a 188 hp Euro SC (stock) without sunroof or a lot of options, but does have A/C and tea tray tail and a little over 1/2 tank of gas. Drivetrain loss was entered at 15%. Average HP results was 197 (190, 178 & 223) |
| All times are GMT -8. The time now is 12:59 PM. |
