irl irl is online now
irl's Avatar
Send a message via AIM to irl
What to do with 3 fuel filters on a 71T
My 71T currently has 3 small silver mahle type fuel filters installed. One just beyond the hard line coming in, and one about 5 inches before each weber. I'd like to replace them for maintenance reasons. Do I continue with 3 mahles in the same place or is there something better I should do????
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-01-2008, 01:59 PM
irl's Avatar
bump, help me pls
79 SC unmolested
25 GTS
Old 12-01-2008, 07:39 PM
If you change the filter number/configuration, I assume you'll have to change the fuel lines too.
For example, you could place two filters in series. One could be a coarser filter for the larger chunks. The second filter could be finer, and since larger particles are removed by filter number 1, filter number 2 should last longer.
Or keep the same setup. Is there an issue with changing 3 filters? It's better to have too many than too few as long as pressure and volume specs aren't compromised.
Sherwood
Old 12-01-2008, 10:00 PM
$75-$150 Racor is nice.
I've run a 2 micron filter for over 20k miles without clogging. I always carry a spare element because things happen in that tight range.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-01-2008, 10:15 PM
I installed a Mercury Marine Water Separating Fuel Filter and (2) Magna Trap #4303VP Inline Filters. I have had this system on for around 10 years.
72' 911S Coupe
Old 12-31-2008, 02:43 PM
Those Magna Trap filters are 60 micron filters sold under various brand names. Does your Marine filter trap particles smaller than 60? If so, I'd recommend swapping their positions so the coarser filters are upstream of the main filter.
MHO,
Sherwood
Old 12-31-2008, 07:04 PM
Navin Johnson
TimT's Avatar
Please get rid of those glass pos filters..
You could get away with just using one of the Mahle filters... remove as many connections from the fuel system as possible...
you could also get one of those Racors... or something like this or this from Canton.
I believe in keeping the fuel supply system as simple as possible...one really good filter... as few connections as possible
'69 911 GT-5
'75 914 GT-3
and others
Old 12-31-2008, 07:18 PM
While those "POS" glass filters pose somewhat of a potential fire hazard in case of a collision, they're a convenient way to observe the amount of crud in the fuel supply system. Then again, a separate fuel pump switch might be minimum required equipment.
In the previous setup, the glass filters appear clean, perhaps because the larger marine filter is removing particles smaller than 60 microns. The end result is that the glass filters are basically along for the ride.
Sherwood
Old 12-31-2008, 07:31 PM
Mercury sourced the filter from a mfg and doubled the list price.
Wild guess is that it's a 30 micron filter? chances are Mercury doesn't even know.
Many marine filters are more for big crap control than keeping a carb clean. Marine Rochester carbs clog up faster than Holley's.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2008, 07:34 PM
Navin Johnson
TimT's Avatar
Recognizing that the OP says this set up has worked for 10 years or so..
I see ten connections in the fuel line that are not necessary... street, race, who cares, there are that many more potential problems..
Also did ya notice how all the fuel line connections are supported....not
Move those glass filters right up into the the garbage can.
irl
one good filter will do all you need
'69 911 GT-5
'75 914 GT-3
and others
Old 12-31-2008, 10:02 PM
many good points by all
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-31-2008, 10:29 PM
Thank you for the constructive criticism. I only want the best for my car. I plan to remove the Glass Filters immediately. Any advice on best set up is much appreciated.
72' 911S Coupe
Old 01-01-2009, 02:44 AM
